View Full Version : I have 3 zones that are not working...
mayhem5220
09-06-2006, 10:05 PM
I have 8 total. Each is set to come on for 10 minutes then repeat. Zone 1-4 work normally. However, zone 5-7 do not come one. They system thinks they are on and gives each one it's ten minutes. Then zone 8 comes on to close the program.
Does anyone have any idea why these 3 zones are not coming on?
Thanks in advance.
prashster
09-07-2006, 06:21 AM
I'd start by inspecting the valves. It's more likely that there are multiple bad valve connections or faulty / dirty valves than it is that you'd have 3 simultaneous leaks in the different lines that were so bad that you'd get NO pressure out of any of the zones.
Gary Swart
09-08-2006, 10:57 PM
Check the electrical wiring, both the hot and the ground wires. Usually the ground wire is daisy chained and a break in the chain would cause the problem.
You could have broken valves, although it would be unusual for three in sequence to break at the same time. You also have to check the electrical connections, and also check if the power is reaching the solenoids. If the solenoids operate, then you have bad valves.
