One of the many problems left to me by my incompetent disappearing contractor is a cretinously installed shower pan and drain in a 2nd floor bath. This is an old house, and everything this guy touched was done wrong--I've spent the last year fixing stuff myself, and wishing I'd had the time to do the work myself in the first place. As far as I can tell from above, he put the bottom part of a two piece drain in *above* the pan, threw away the top part, didn't intall a riser, and used a 1 1/2" p-trap, butted against the drain and sealed from above with a huge amount of plumber's putty. Surprisingly, this hasn't leaked for an entire year, until the putty started to fall away--there's now a tiny spot on the ceiling below. I jammed in some more putty as a stop-gap. I've seen the Wingtite drain, but don't think it'll work because of the lack of a proper 2" riser. We just bought the house and did much work, so money is tight, so for now I really want to avoid pulling the ceiling out and re-doing it all properly, especially because it's our only shower. Also, I know that as soon as we get in there, there are going to be more stupid problems--I suspect he also screwed up the concrete he used to level the floor. I realize it would only be another stopgap, but would it be a terrible idea to replace the putty with waterproof epoxy (like Harvey's) and hope that will tide me over for a while longer? I don't want to create bigger problems further down the line, but am between a rock and a hard place. Thanks.
