3/8" compressions to 3/4" Pipe adapter
Chefwong
District of Columbia
Have any of you ever seen a 3/8" female compression to 3/4" Male brass adapter ? It's for a angle supple stop/dishwasher water feed .
Trying to avoid the compression adapter 3/8" - 3/4 piece and trying to do a straight angle stop to adapter route.
I don't know if such a fitting exists, but I can tell you that if you need fittings that are not commonly used, the big boxes can help you. You need to go where the pros go, a legitimate plumbing supply house. You may find some that will not sell to you, a non-professional, but many will make a cash sale for single items. At least they could tell if if what you want does exist and if not, offer an alternative to meet your needs.
If you've got the room, it might be easier for you to locate and use a 3/8 female compression to 1/2" and a 1/2" to 3/4" adapter than to locate and purchase a single 3/8 by 3/4 adapter. I'd try a hardware store.
-Sam
I currently have a 3/8 to 3/4 adapter. It's currenty connected via compression fittings and a small piece of 3/8" tubing.....never been a fan of compression fittings...as opposed to threaded brass fittings.
