GLIINC
08-28-2006, 08:25 AM
I recently installed a 11 zone system with a 3/4 hsp goulds booster pump.
When we first started the system everthing worked fine. A few days later
we were having a problem with zones 6 and 7, the pump on these two zone would just make a sucking noise for about 8 to 10 minutes then the pump starts pushing and workes properly. All other zones in the yard work properly. The zone in question are spray zones with less gpm than most zone in the yard. We have tried several differant this to fix it with no sucess.
We replaced the pump, pump start relay, controll box, valves on both zones, put on smaller nozzels, caped heads to make smaller zones and nothing seems to change the problem. When we first changed the pump we thought we had it fixed as its worked at first but the problem started again after a few runs.
If anyone out ther can help it would be greatly appreciated.
