View Full Version : 1 1/2" Copper Shower Drain NG in MA
Michael V
08-26-2006, 05:36 PM
I demolished my 2nd floor tiled shower. After removing the copper pan, I was left with a 1 1/2 copper drain pipe. I know this is not code in MA. Wanting to do things correctly (not sure if I am going to have it inspected), I opened up the floor to trace the drain pipe to the stack. It is threaded 1 1/2K to the cast iron.
I'll try to post a picture.
What can be done to make it a 2" line?
Thanks,
Michael
Michael V
08-26-2006, 05:54 PM
To answer a few questions before they may be asked;
The drain line is about 5 1/2' long.
The large pipe to the right of the 1 1/2 copper drain is from the toilet.
The two pipes on top of the copper drain pipe are the hot and cold water supply to the shower,
they make a 90 degree turn in the direction of the shower right (I guess) after the drain for the toilet.
Hope this helps.
Michael
Bob NH
08-26-2006, 06:03 PM
Somehow that toilet pipe looks like it runs up hill into the same pipe that the shower drain is going into. Is that an optical illusion?
Michael V
08-26-2006, 06:40 PM
Yes Bob it's an illusion,
There has never been a problem with smells or draining (that a quick snaking didn't fix). I've had to snake the shower drain a couple of times in 20 years. The house was buillt in the 60's and we moved in during the 80's.
The shower drain appears to be connected to a 1 1/2" tapped opening. if so, then the only option is to remove the tee and change it to one with a 2" opening. If what we see is all there is then the shower drain is both undersized and improperly installed.
