mandjknight
08-24-2006, 09:45 PM
Hi Everybody,
I've got a dumb question. I'm hooking up a Craftsman 2 HP Lawn Sprinkler Pump. I've got everything dry fit and ready to go but I'm kind of confused on the electrical connection. It requires it's own 230 Volt connection. I've got the right type of wire and dedicated circuit, but I just can't figure out where the neutral wire connects.
I've got some heavy duty 10 gauge outdoor/underground wire coming from the service panel on the side of a shed (dedicated 30 amp circuit). The wire has a ground wire, neutral wire (white), red wire (hot), black wire (hot), as you would expect. The motor on the pump has an obvious place for the ground wire and two "Lines" for the two hot leads. Where does the neutral lead go?
The manual has two wiring diagrams.....neither of which apply. They both show wiring diagrams for a 230 Volt to 115 Volt Conversion which doesn't apply to the 2HP pump because it requires 230 Volts. What am I missing here?
Attached is a picture showing the motor with the neutral, and hot leads connected.
I'm not much of an electrician but figured I could at least connect this pump.
http://i21.photobucket.com/albums/b253/mandjknight/SprinklerPumpWiring.jpg
