Is there a trick to keeping one-inch gas black pipe from leaking?
I have a contractor who did his own house with no problems. But he used half-inch black pipe rather than one-inch.
I need to use one-inch in order to keep the inspector happy because I'm teeing off the one-inch that goes to my cooktop so that I can feed a 3/4 inch pipe for a fire pit.
My contractor seems to be doing everything right. He's using pipe dope and is tightening things down. He may be overtightening ... but if he doesn't tighten as much as he does then things leak.
He's super-frustrated because he's spent four days on only thirty feet of pipe. There are eight elbows in that run. He's not charging me for his time (because, he says, that he should know what he's doing) but since he's a friend I don't want to ream him. He's done a superb job on electircal and water plumbing and carpentry and he's been paid well ... but, still, he's a friend.
So some general questions:
a) Does one apply pipe dope to both the inside and outside threads?
b) Does one-inch pipe need to be tightened more than half-inch?
c) Can fittings be used more than once? Do they need to be totally clean if being reused?
d) If the joint leaks and tightening doesn't solve the problem and the joint continues to leak, what should we do?
