View Full Version : Install: Is caulking the base really necessary?
lairdwd
08-20-2006, 06:03 PM
Hi folks.
My plumber told me they don't caulk, and left it up to my discression to do so. THe toilet is very steady, and there is no wobbling, so I'm really wondering more for down the road if the caulk has any added value to enhancing the longevity of the setup/components.
Second question - in Jamie's instructions, he recommends sanding down the inside of the bowl where the rubber gasket attaches. Assuming this step was omitted, and install is fine, will this cause problems down the road? Why does Jamie do this?
Thanks, you guys are the best! I've learned so much from this forum.
Cheers,
Bill
jadnashua
08-20-2006, 06:09 PM
In some places, the inspector want the thing caulked. It also helps keep crud from dribbling under the toilet where you can't see it or clean it easily. Last, it helps anchor the thing to the floor better to help prevent it from getting knocked if someone happens to fall against it.
If the casting is rough, it is hard to get a good seal. If you got one, then no problem...
Verdeboy
08-20-2006, 08:49 PM
Caulking a toilet is very important if there is a room, apartment, etc., underneath. If the toilet or tub overflows, it will minimize water damage to the ceiling below. Other than that, it might be necessary to caulk a toilet if the toilet flange is slightly higher than the floor, to help stabilize it after it has been shimmed.
