How high can the tie-in to the drain pipe in the wall be on an Island Sink?
Right now I'm looking at about 25 inches. I have about 14.5 feet to go to hit the main 3" drain pipe in the basement from where the sink will be in the Island. The height of the drain pipe at the sink is dictated by the allowable slope (1/4" per foot) and by the minimum height for the tie-in to the 3" line based on the Wye pipe that will go there. Based on a quick measurement it looks like the lowest I can go at the sink is about 25". Typically the pipe height for a drain is about 17". Is 25" too high or will that work as long as I select the right sink?
I'm wondering if there is a minimum height above the trap? Or, is there a minimum distance below the bottom of the sink the pipe has to be?
As long as the pipe is below the sink and has the proper slope and vent, it will work but there is always the issue of what an inspector will accept.
re5513.
re5513.
