Recently, our toilet has been occassionally filling with hot water instead of cold. This primarily happens when the toilet hasn’t been flushed in a few hours (such as first thing in the morning). As we continue to flush, the water goes from hot to warm to cold, and the flushes stay cold until the toilet isn’t used again for a few hours. We live in a condo building, and have been advised by the building’s plumbers that this is likely caused by faulty mixing valves which are located behind the shower faucet, which is causing the hot and cold water supplies to get “mixed upâ€. They did not examine anything, just simply stated that this is what is causing the problem and quoted around $1200 to replace the valves. However, if this was the case, wouldn’t the water be mixed up for other things in the bathroom, such as our shower, bathtub, sink, and washing machine (located in the bathroom), and would this occurrence not happen at all times, not just when the toilet hasn’t been used for a few hours? I am not sure if this is pertinent, but when the faucets in the sink and shower haven’t been used for a few hours we get only hot water from them (no cold) for a few seconds when the taps are initially turned on. We have not done any work in our bathroom recently, so it wouldn’t be as a result of that. Any advice would be most appreciated as I would like to have some idea of what could be causing this before having a plumber in. Thanks!!
