Help with toilet.. please
orenna
Hi.. I was wondering if anyone had any ideas. Our toilet got clogged and we tried to use a plunger with no success.. the water wouldn't even go down. So we got an auger and after I used it twice.. the water went down and was clear. But the toilet still does not flush as well as it did and while the water does slowly flush down.. I am worried about solids/toilet paper.. Does anyone have any other ideas??? :confused:
Thanks so much
Carrie
Sounds like the auger pushed the clog further down the drain. Might be time for a real snake to clean it out.
One of the problems we DIYers have is we tend to take a knife to a gunfight. Augers that most of us have access to are just too small to get the job done. They may work sometimes, but it sounds like you have a clog that is too deep for the tool you are using. Sometimes even the most avid DIYer has to give up and call the pros. I think this is one of those times.
One way I have been able to clear deep clogs is to get a couple of 5 gallon buckets of water at hand and start the toilet flushing. Once the flush is established feed the water to the toilet as fast as it can take it. This puts a lot of presssure on the clog and is sometimes successful. At least it is cheap. Good luck, RW
clog
I don't think you pushed a clog deeper. after all, the toilet trap is a lot smaller than the sewer pipe.
The first thing that comes to mind is there is still an object in the toilet bowl .
You may have just cleared the bowl of paper. Get a real closet auger and use it. Depending whats in there, it may pull back a pencil, comb, toy, or something from a shelf or counter top.
When your all done do the paper test. flush the toilet with a good amount of paper 3 or 4 times.
