CharlieM
07-08-2006, 02:57 PM
I just installed a Delta single-handle shower valve in an acrylic shower enclosure and I'm wondering how to seal up around the cover plate.
No matter how I adjust the plate, there is a small gap in the seal on the plate around the valve handle area. There is a foam ring on the cover plate, but it seems far from adequate to actually seal around the valve. Water bouncing off a body will almost certainly find it's way past this. Is this an area best left to silicone caulk ?
Also, should I run a bead of caulk around the outer rim of the cover plate ?
Thanks,
Charlie
Thanks,
Charlie
