View Full Version : fiberglass tub apron removal
dimmi
07-05-2006, 07:42 PM
How do I remove the large panel (72"x18") from the tub so I can access the plumbing? Can I cut the whole thing off and replace it with a tiled panel? The only access panel is in the closet next to the bathroom. It opens up were the pump is. The faucets are about 60" from that panel. I don't know the brand but it was put in by the builder in 1992. Thank you for your help. Dimmi.
Pewterpower
07-05-2006, 09:01 PM
Why can't you open the wall from the other side of the tub wall? I don't think you want to cut into the Hardi or greenboard or whatever was used on the tub side of the wall, unless you have no choice.
07-05-2006, 09:47 PM
Why do you have to access it?
dimmi
07-06-2006, 12:02 PM
the other wall is exterior cement block. I need to change the roman tub faucet.
dimmi
07-06-2006, 11:03 PM
should I cut the panel off and replace it with a tiled apron?
