hard to find drain
leeh
Maryland by choice
I have purchased a St Thomas vessel sink that has a Drain opening of 1 3/4" OD. It doesn't have an overflow. The faucet I've purchased is a Belle Foret Wall Mount Vessel filler. I am looking for a drain in oil rubbed bronze that will work with this sink. Any help for this Fourth of July Birthday Girl will be greatly appreciated and received as a fantastic birthday gift. :)
I do not know model numbers but Kohler does have a pop-up in rubbed bronze that does not have an overflow, check with your plumbing supply stores. It fits their serpentine sink.
Thank You
Very appreciative to both of you for the leads. Isn't the 1 3/4 " OD drain opening a odd size? Seems that most drains I find are 1 1/4" which seem a bit too small to fit this opening. St Thomas Creation makes a drain to fit...but I can't locate it and even the company is vague on where. Thanks again.
Perhaps "Thanks" was premature
EDJ, I researched your suggestion and, as the copy below shows, it too has a 1 1/4" connection. Doesn't this St Thomas Creation vessel sink with its 1 3/4" OD opening require something a bit larger. I am no plumber, but the local plumbing supply is stumped as well. Lee
:( Kohler model# 7702 Pop-up lavatory drain (non-ADA application)
Intended for lavatory installations without an overflow, this pop-up lavatory drain features an undercounter mount actuator with a lever handle and solid brass construction. It includes optional linkage for countertop installations
1-1/4" Connection
Great Outdoor
hj, can you give me a lead on where I can find this manufacturer. Not coming up with anything related to plumbing parts online. One I do find seems to manufacture BBQ grills and other unrelated items. Thanks, Lee :confused:
I should read a bit more carefully
hj, I reread your post and see that I had misread Great Indoors as Outdoors. I will try my search again. Thanks. Lee
