Advice on Concrete acid stain
Mike50
DIY Senior Member
Southern California
I'm almost ready to do some DIY indoor acid stain.
What garden sprayer that can tolerate acid would you recommend??
What Dremel attachment should I use to remove some minor paint stains from concrete slab.??
(I may use solvents as well-but they can smear)
I used the cheapest sprayer form the hardware store to spray my floors. They are the only ones I found with all plastic parts.
The drawback is that the ones I had dribbled. That leaves marks in the stained floor. Try one out with water before deciding.
Thanks mate. As it turns out plans changed-but I will keep that in mind.
Mike
