I'm running some new copper supply pipes up to my attic for a new bathroom. Because of the odd layout of fixtures and the fact that one of the walls is going to support a new dormer, I was thinking of running most of the supply pipes in the floor.
I'd just drill some 1" holes in the joists, according to code requirements. I think it would be the easiest way to get the pipes where they need to go.
Except I worry that if there's a leak or something down the road, the pipes are all concealed under a lot of flooring. There'll be subfloor and then tile on top.
Is it a better idea to put supply pipes in the walls for easier access in case repairs are needed? Or if my system tests okay, should I assume it's okay in the floor?
Thanks.
Thanks.
