millerscr
06-23-2006, 12:38 PM
I supposedly have a well around 80 feet deep. The motor is a goulds jet pump 1 HP.
We have low water volume. Pressure builds up and we have a good supply until tank begins to deplete, then we have a barely adequate supply out of a faucet. There is a single pipe through wall 2” OD that must have both a feed and return line to the well, as the pump sits just inside the wall on top with the tank next to it. Not every day however beginning quite frequently we are loosing the prime on the pump and I can use a couple hundred foot of hose from neighbors house to re-prime, coupling it up to a faucet. The symptoms are, low volume, loosing prime, and our pipes that are suspended surge when our pump is running, actually bounce up and down sometimes as tank is building pressure. Looking for some suggestions, and would it be possible to put in a submersible pump instead or would this be a bad idea.
