View Full Version : Converting copper to Cpvc.
lynkel
06-22-2006, 04:21 AM
What would be the best method of converting 3/4 copper tubing to 3/4 cpvc?
Should I use a male copper adapter into a female cpvc fitting,or a female copper fitting with a male cpvc fitting screwed into it.
I read a post somewhere that said one or the other is more prone to leaks,but I can't remember which one.
Also,I have read that you should not use teflon tape when joining fittings.
Is this true?
Thanks for any help.
Cass
06-22-2006, 04:27 AM
Female copper Adp. and screw a male CPVC adap. into it.
06-22-2006, 06:08 AM
And be sure to use a male CPVC adapter with brass threads, not plastic ones.
dowop
07-11-2006, 07:23 PM
This is what I've used many times without problems. Brass on both sides. See the transition fittings at the bottom of the page.
http://www.nibco.com/cms.do?d-1342853-p=3&pId=59&id=2
