In the process of tearing out my bathroom tile floor to install a new tile floor, I discovered that the PVC toilet flange was simply resting in the concrete mud base layer and draining into a second, lower PVC flange on the plywood subfloor. It wasn't even glued in to the system. Since I needed to have the flange at a higher level for the new tile floor that I plan to install, I decided to cut out the lower flange, install a 3-inch PVC coupler, and run a short length of 3-inch PVC up to the level of the new flange.
Well, tonight I used a Dremel cutting tool to cut out the top of the flange. But to my dismay, the bottom of the flange butts up against the edge of the elbow joint. There is not enough 3-inch pipe exposed to attach the coupler. Right now I have a cleanly cut off 3-inch pipe with the bottom part of the flange fused around it.
I need to get a flange to about 3 or 4 inches above this cut pipe. What are my options? Are there PVC parts avialable to deal with this type of situation?
Thanks.
Thanks.
