I thought this post might have been buried because I hadn't updated for a while...
I've attached two photos and would appreciate any advice on them. I was unable to fully draw everything I wanted - like the vent from the sink coming around to a 3" vent pipe near the toilet.
Here's what I'm struggling with:
1) Where to locate the 3" vent through the roof. This is an unfinished attic space so the ceiling dimensions slope. Since the vents must be above the highest fixture it might need to be located towards the center of the room.
2) Where do I vent the toilet? If you are standing in front of the toilet, the drain for the lav turns left and then must go through a floor joist and straight down a vertical wall. I drew a plan using two 45's and a bit of straight pipe, but that might be wishful thinking if I actually want it to go down the wall without widening it or building a little soffit.
I just can't tell right now if I'll be able to get a vent (especially a 3" one) to the lav dwv before it turns down the wall. I have a few ideas, so I'll make a sketch.
3) If I take out the 3" vent pipe I now have coming from the lav drain before it turns down the wall, can I put a vent for the toilet in that vertical wall with a T/Y combo? It wouldn't be very far from the toilet, but it would be below the toilet. I'll sketch it.
All advice greatly appreciated! Sorry if the pictures are bad. I had a heck of a time getting my scanner to scan within all the ranges the site wants.
