View Full Version : Visible shut offs, options for appearance?
MartinM
06-11-2006, 12:55 PM
Hi guys, wondering if you could share how you handle when shut offs are clearly visible. Have 2 situations on our remodel. One bathroom you walk in and the toilet is on the left wall so the shut off is clearly visible, and the other bathroom will have a pedestal sink where you can see its shut offs pretty easy.
The pedestal I have new stubs coming out, and the toilet I will run a new stub out of the wall. I was wondering if there was a chrome sleeve or something they made that goes over the copper and would slide into an escution plate.. Not sure, has to be some way of making it look nicer than just copper coming out and a valve.
Thanks
Lancaster
06-11-2006, 01:18 PM
Yes,you can buy chrome (also other finish) cover tubes that are about 3 inches long.You need to get a 3/8" ips escutcheon to fit over them.
jadnashua
06-11-2006, 01:32 PM
Brasscraft has one that solders onto a 1/2" copper pipe stub. It is about 5" long. I bought one at HD awhile ago.
master plumber mark
06-11-2006, 05:02 PM
something else that works great and
we used to do it all the time in new construction.......
just tin the copper pipe comming out of the
wall silver and then wipe it off with a tining rag
..makeing the pipe silver- chrome.....
it looks like chrome, acts like crome.....
it lasts about 20 years
and no body cares to get
close enough to really check it out.....
or you can go to wall mart and buy a small bottle of
silver -chrome touch up paint in the automotive section
for about 2 bucks.....
I use it to "touch up " knicks and scratches
kordts
06-11-2006, 08:48 PM
I cut the pipe off about 2" from the wall and shine it with grit cloth. Use a chrome valve and escutcheon and it looks great.
Mikey
06-12-2006, 03:29 AM
Clean the polished copper with acetone and paint it with clear nail polish or lacquer to preserve the shine, or be prepared to re-polish it every couple of months.
MartinM
06-18-2006, 10:15 PM
Do these have a specific name or anything I could look up? Tried to find some at the home centers and came up empty. Just think a cover would be the easiest. if I can't find anything maybe I will just paint the thing though.
Thanks guys.
plumber1
06-19-2006, 06:34 AM
I like kordts idea best.
I would use chrome stops with compression on the inlet and outlet.
If you cut the copper just long enough, you won't see any copper............
after the valve is installed.
Mikey
06-19-2006, 06:39 AM
As mentioned earlier, they're called escutcheons; both HD and Lowe's carry them in my town but if your town doesn't, they're a click away:
http://www.****************.com/escutch.html
Lancaster
06-19-2006, 02:43 PM
Look at the Brasscraft catalog
http://www.brasscraft.com/Default.aspx?Page=Prod_WaterSupply.aspx
and look about half way down page 64 "cover tubes" item #8489
