Pipe replacement
nzairforce
Aerospace Engineer
Bronx, NY
Howdy Everyone!
Great site. Lots of information.
I am remodelling my bathroom, and I want to replace and reroute some plumbing, water pipes for vanity and shower.
Below is a picture of what I want to tackle. The pipe running up the wall goes to the shower, the ones heading away from the wall are the vanity pipes. The vanity pipes run over the floor joists, so I want to reroute them below so that I can install a new floor. I'm not sure what the existing pipes are made of, but they may be brass. Other photo is some that I buffed up to find out. I want to change to copper piping for the shower and vanity piping, from the T-junction in the first picture. My question is: Can I just attach copper fittings directly to the "T" if this is Brass, or do I need to get some sort of dielectric fitting for the transition? Any help would be greatly appreciated. Thanks.
Check to see if the pipe is magnetic. If magnetic, it's steel; if not it's probably brass. Copper is compatible with brass and most people put copper to steel without dielectric unions.
Great!!
Cheers Bob! I really appreciate the quick reply. I'll go and check that out now.
More pipes
Howdy!
Can someone please give me some insight on how I would go about replacing this pipe? I appears to be made of lead, and there also appears to be lead "melted" into the connection with the main waste pipe. Any thoughts? Thanks. :confused:
cut ti off
their is a 6 inch brass nipple comming out of that cast iron tee....
you can see where the bulge is.....and where the brass is welded to
the lead flange....
if you simply take a hack saw and cut it off down to that brass nipple
then melt away the excess lead off the brass with a torch,
and wipe it clean to the brass nipple
you should be able to attach a 4x3 fernco fitting right onto
that brass nipple... and convert it to PVC pipe....
and it off to the races...
