View Full Version : Sewage ejector system
brandonvarnell
06-06-2006, 09:18 PM
Hi, I am considering putting a bathroom in my basement. I have done tons of research on the sewage ejector systems and I think it is the best route to take. However, I have some concerns about what the finished product is going to look like. I cant find any pictures of finished bathrooms that have ejector systems. Can anyone give me some pictures to look at?
Edit/Delete Message
Dunbar Plumbing
06-06-2006, 09:50 PM
If you go with the type that you have a pit and the groundwork piping is installed under the concrete then all bathrooms follow the same look.
You can go to Zoeller.com's website to see how the above ground units look.
Just envision having to step up to use the toilet or walk on a platform to get into your new bathroom. Real estate agents have a lasting opinion on the market value of those types of bathrooms.
The ones with the pit in the floor seem to hold the highest value.
Mikey
06-07-2006, 06:41 AM
Fine Homebuilding often has ads in it for such systems, with pictures. I don't recall them looking particularly ugly, and there was no platform. I may be confusing these with incinerator systems, just the thought of which scares me, but apparently they work OK.
prashster
06-07-2006, 07:08 AM
'Sewage ejector' system is a generic term that can mean an above-ground unit or an inground unit.
The above-ground units are easier to install, but have smaller discharges and inlets and are prone to clogging (that's what I read, at least). Also, you're limited in yr choice of toilets to rear-discharge ones. However, with clever placement, the unit can be hidden behind a wall and yr bathroom will 'look' just like a regular one - except for the shower, which will have to be on a platform.
The in-ground units are more bigger and more powerful, which means fewer clogs and a longer life. However, these require concrete excavation. Concrete digging is not hard if you don't mind dust-I mean a lot of dust, have a strong back, and if your water table is fairly low.
You can have a handyman jack the 'crete for a fraction of the $3000-6000 a plumber might charge to do the whole rough job (which might be your best option since they'll route yr water supplies and vent too).
