View Full Version : Solder question
MartinM
06-06-2006, 07:24 PM
Had just a quick question on Solder diameter. Haven't sweated a joint in a while, last time I did a retired plumber taught me and was kind enough to let me use most of his goodies.
Used Oatley 95, which I have found.. And I believe I used Bridgit solder. I would like to just get what I originally used since I had no issues.
Was looking around online and while not finding many places, I see it comes in different diameters. I was assuming the standard is 1/8th(.125)? Is that the norm for sweating 1/2 and a few 3/4 copper? Or another size?
Also anyone by chance know a site online to order the Bridgit?
Thanks
Lakee911
06-06-2006, 08:02 PM
For plumbing, I've only seen 1/8" but I'm a DIY and it works so I use it. I've had good luck w/ all brands.
Good Luck
Jason
Cass
06-07-2006, 06:20 AM
For a DIYr about any lead free solder should work fine for a few joints or a small project.
You don't need to be picky. Plumbers are picky because the do so much of it, but will use what ever solder they can find if they need to.
prashster
06-07-2006, 07:30 AM
Use the Oatey 95. You won't have problems. If you search this forum for solder, you'll find that Oatey 95 is a favorite.
