View Full Version : Under Slab C.Iron to Plastic Couplers
tsawicki
09-13-2004, 09:45 AM
I need to connect a plastic pipe to my cast iron main drain line under the basement slab.
I have read about mission couplers and looking at the Fernco website wonder if these are the couplers referred to here and elsewhere:
http://www.fernco.com/NH.html (Fernco Website - No Hub Couplers)
Description from the website:
AISI 304 Stainless Steel Shield
AISI Stainless Steel Clamps and Screw Housing:
Full size 9/16" wide bands and one piece screw housings are mechanically interlocked for strength. The wide clamp band provides enhanced sealing force.
Specially Beaded Gasket:
Unique beaded Neoprene gasket grips with superior holding and sealing power. Gasket conforms to ASTM C 564.
HD-4000 Couplings:
meet ASTM C 1277 and meet test criteria of CISPI 310.
Thanks for any help,
Todd
Dunbar Plumbing
06-27-2005, 09:09 PM
Most areas just the rubber ferncos without the band is code but you can install shielded no hub mission couplings underground.
