Yesterday my neighbor approached me with a plumbing problem (I am a licensed plumber). They told me that their water bill has almost doubled and their electric bill went up. At first I thoughjt this was a no brainer, an under slab hot water leak. However when I began checking it out I noticed that the hot water has already been rerouted overhead. The water heater had a tapping sound originating in it and the cold water pressure was fluctuating at the kitchen sink. Turned off the valve above the heater and the tapping stopped and the water pressure at the kitchen sink equalized. Turned the valve at the water heater on the tapping, fluctuating resumed and the water meter ran at about 1 gallon/min. Turned the valve off and the meter stopped.
I put a pressure gauge on the hot water at the laundry tray and turned off the valve at the heater, the pressure did not drop as expected. However I did notice low water pressure (25 psi). I then put the gauge on the hose bibb where the water enters the house, the incoming water pressure was 25 psi. I adjusted the PRV to 50 lbs. Now all the symptoms have stopped. The pressure no longer fluctuates at the kitchen (it was actually fluctuating throughout the cold water side), the tapping at the heater has ceased, and the meter no longer runs.
Has anyone run into a similar situation? Can a faulty/low setting on the PRV cause such problems? Been plumbing for 16 years and this is a new one on me. That's what I like about plumbing, no matter what you have run into, you havn't seen it all yet.b
