View Full Version : tank wobbly and leaks when leaned on
CindyE
05-25-2006, 10:43 AM
We recently had a Toto Whitney toilet installed by a friend. I noticed the tank is wobbly compared to our previous toilet. We had no problem with leaks until I pushed down on the toilet tank and heard a spray of water. I am assuming the tank is not bolted down tight enough. Do we need to take the tank off and reinstall? Thanks for any help..
05-25-2006, 10:51 AM
http://www.terrylove.com/wc/toto/drake_sand_bolt3.jpg
We normally sand the inside of the tank first
http://www.terrylove.com/wc/toto/drake_angle2.jpg
And then we tighten down the tank pretty well.
It may be that you just need to finish tightening the tank to the bowl.
RRW
05-25-2006, 01:01 PM
When you say you heard a "spray", to me that sounds like a pressure part of the water supply is leaking. Maybe you have a hard line connecting the water supply to the tank rather than a flex line, and when you lean on the tank you are overstressing the connections of the hardline to either the tank or wall valve. Good luck
