hello there. i'm completely new to pumps and plumbing, so please bare with me.
my family owns a water pump business. we fill 5gallon jugs and such. recently, our machines don't vend water consistently anymore. the pressure would drop and we'd have to manually work the machine to regain psi to pump water for our customers.
i think the problem is with the pumptrop square d, type fsg22. i'm not quite sure how it works though.
this unit has an air valve that's connected to a pump and a gauge. currently, the gauge reads 0 psi. and the pumptrol's contacts are closed.
before when everything was fine, the gauge would read 20psi, and everytime the psi drops below 20psi, the pumptrol's contacts would connect and cause the pressure to rise to about 40psi. after running awhile, the contacts would disconnect.
so now the contacts are just closed and nothing happens...it doesn't run anymore, nothing pumps.
could the air valve be clogged? could the pumptrol be broken?
please help me with this. any suggestions would be greatly appreciated. thanks for your time.
