DanMcD
05-17-2006, 04:20 PM
I had a new brass drain installed in my neo-angle shower. The PVC pipe is press fitted into the brass fitting that has about two inches of rubber casket that seals against the PVC pipe.
My question is: will this not leak over time?
Shouldn’t the plumber put caulk around the top edge of the PVC pipe (around the pipe edge that you can see if you pull off the top strainer)?
Dan
Dan
