Yellow Teflon Tape
Chicago
Can you tell me if the yellow tape is safer than the white. I know that it"s thicker, but if the white is wrapped around the pipe an extra turn, wouldn't it be the same? :confused:
Thanks...you guys are great!
What is your application? Several layers of white tape often works, but sometimes it doesn't. Paste is good in cases where tape won't work. I think yellow is for gas pipe, but I have never used yellow tape or work with gas piping.
On tapered pipe threads, maybe (but not allowed where I am licensed).
If you have a pre-made, flexible gas connector, then by all means no. The threads on such fittings are running threads, much like a nut and bolt. Such threads only purpose is to 'smash' the piping against a fitting. Any tape dope will only serve to hinder the 'smashing' of the tubing against the fitting.
If it is a flexible gas connector, take time to read the tag on it, if it hasn't been removed. Lot's of info there. Espescially how they are single use items: once they're connected, that's it.
If you are using trak-pipe or wardflex, the threads serve the same purpose as above. Then again, I had to watch a couple videos, assemble a joint or two and take a test to be able to work on that stuff.
As already stated, yellow is for gas plumbing. Personally I prefer regular plumber pipe dope. For me, pipe dope is faster and easier than tape. Some guys use both, but I'm not sure there's a benefit to do so. Also, only use tape or dope on tapered threads.
From the plumber and writer Peter Hemp
use 4 tight wraps tape then rector seal #5. with this combo you can back off a gas fitting 90 degrees , and never have a leak.
hj said:
FLOCCINAUCINIHILIPILIFICATION
The action or habit of judging something to be worthless
I guess that means the word is self defining.
Nice wit, I like it.
I believe that the yellow is reated for gas as well as water or air. I find it easier to just use pipe dope though. I only use tape when I do not want to make a mess.
So I guess you FLOCCINAUCINIHILIPILIFICATION the word FLOCCINAUCINIHILIPILIFICATION and deemed it to be worthless.
