View Full Version : Sewer Gas
fireman_103
05-15-2006, 07:31 AM
I have a 2000 Model doublewide Mobile home. There is a horrible smell of sewer gas that seems to come mainly from the Master Bath. I have taken a quick peep under the trailer and I cant seem to notice any traps comming from the bath fixtures. The bath tub will drain quicker than anything I have ever seen. Should I purchase and install traps on shower and tub. Are they actually required? I had the septic people out to check my system and get the pump running and they said the smell should go away in a few days, This was three weeks ago.
Gary Swart
05-15-2006, 08:13 AM
I find it hard to believe that your home was built with traps, but every drain must have a trap or you will get sewer gas. This has nothing to do with where the drain goes after it leave the house, city sewer or septic tank it makes no difference. That said, you should remember that toilets have their trap built in so no other trap is required. Tubs and showers must be trapped and vented.
I think Gary meant he found it hard to beleive it was built without traps.
Gary Swart
05-15-2006, 11:01 AM
Hey! I was still on my first cup of coffee when I wrote that. Indeed, that is what I meant, thanks Cass.
plumber1
05-15-2006, 03:11 PM
The traps for the shower and bath tub are probably in the cavity between the bottom side of the floor and above panel under the double wide.
You can get a smell from the vent on the roof. A down draft from the roof can be drawn into the home, particular on days when the air outside is heavy or muggy.
