Outdoors above ground, some areas will require you to use black pipe and wrap or paint it. Some areas will require galvanized. Underground, galvanized used to be used a lot, but is no longer accepted. Here, the green epoxy coated is the norm, but failure to properly wrap the joints will also cause failure of that. Plastic pipe, which cannot be installed by homeowners, will eventually replace steel pipe in the codes I believe.
