Does a lavatory sanitary Tee / p-trap flange that drains into a combo Wye in the middle of a horizontal drain run with more than 135 deg turns count as a cleanout? Thanks!
Not always, because it is only 1 1/4" or 1 1/2" and a cleanout has to be the same size as the pipe or 4" whichever is smaller. And some codes do not recognize any cleanout that requires that the drain be disassembled to use it. WE always have to install a cleanout tee below the fixture connection tee in the vertical riser if that fixture needs a cleanout.
