You need (a) turn OFF the water supply, (b) remove the bonnets around the valve stem handles (they may unscrew or pry off, either one), and (c) unscrew the valves out counter-clockwise.
Take the valves to a hardware store and replace the rubber o-rings around the valves and the rubber washers on the ends of the stems.
Good Luck!
Mike
