View Full Version : Tired of Mixet shower handles
sdcabob
04-21-2006, 08:48 AM
I'd like to replace 2 showers with Mixet with a different brand. I'm told that these pieces must be replaced with same brand due to match with valve.
True? Or are there other brands to choose from that can fit on these valves too?
Am trying to avoid going through tile and dry wall for repair if possible. Thanks!
master plumber mark
04-21-2006, 09:37 AM
no, you are screwed....they are a pain
you will have to cut them out from behind
and preferrably install DELTA 1700
pressure balanced faucets....
Once you access the brass part in the wall, you can install any valve you want to. But I also prefer the Delta 1700 series.
jimbo
04-21-2006, 09:37 PM
You cannot REPAIR your shower with anything but Mixet parts. Faucet parts are not generic at all......must match brand and model. The best you could to is possibly find a brushed nickel escutcheon. Mixet parts are getting scarce.
If you can get access inside the wall, from the front OR from the backside, then you can install any new shower valve you wish.
Jimbo. One company makes a Moen style cartridge for the Mixet which eliminates the crossover problem common with Mixets.
jimbo
04-22-2006, 09:35 AM
Thanks hj. I jave heard of that anit-crossover cartridge, but have not used it. My point was also that choices of upgrading the "look" are limited to the brand. Does that aftermarket cartridge require still the Mixet handles, or doe it use Moen handles and trim. If the latter is the case, that would open up a few more opportunities as far as handle and trim styles and colors.
I haven't used any either, but I had many apartment complexes in the early 70's that had serious crossover problems to the point where the apartments at the end of the runs could not get any hot water at all. These would have fixed them. They use the Mixet body, so you have to use Mixet trim.
schneider120@hotmail.com
07-25-2009, 03:27 PM
DID YOU EVER FIND OUT OF YOU CAN USE OTHER NON MIXET TRIM AFTERWARD?
The body requires the mixet trim plate, and the replacement cartridge requires the Mixet shut off knob to control both flow and temperature just like a Moen valve. Nomix Inc. repair cartridges that fit Mixet brand valves (http://www.no-mix.com/)
jimbo
07-25-2009, 07:32 PM
Notice the price on the NOMIX. You have to be dedicated to stay with Mixet/
