View Full Version : Bath tub clogged
Mike50
04-21-2006, 08:24 AM
Bath tub clogged for 24 hours. Standing water removed. Tried plunger then 2 applications of Red Devil Lye with no success yesterday.
I'm thinking about just buying an inexpensive snake at local big box or renting one from my the hardware store. (brand recommendation?)
Do I neutralize the lye and with what?
Drain likely clogged with cotton mop strands.
Is there an easier method or am I on the right track here......?
Have very little experience as the plumbing Gods have been good to me over the years. I'd like to handle this myself.
plumber1
04-21-2006, 09:59 AM
Keep the darned lye out of your drains. IT REALLY DOESN'T DO ANY GOOD, YET CAUSES OTHER PROBLEMS,
Now someone has to deal with the chemical. (it's not magic!).........
The drain needs to be cleaned out with a good electric snake......
Hope that's emphatic enough.
Gary Swart
04-21-2006, 12:02 PM
Chemicals seldom clear a clogged drain. Sometimes if it's just soap scuz and hair in the trap they will open, but usually chemicals just create a hazzard for the person who eventually will have to snake the drain. The DIY snakes also are too little to open a clog. They often just push the clog deeper and tighter. Contact a plumber who can professionally auger the drain. Tell him what you put in, how much, and when.
Mike50
04-21-2006, 03:25 PM
OK I hear you loud and clear.
I suspected that the consumer snakes were not effective and I will pass on buying one.
thanks..
Mike
Bob NH
04-21-2006, 03:46 PM
Lye is a base, sodium hydroxide, so to neutralize it you need acid. Muriatic acid is HCl. The problem is to get it into the pipe that contains the lye.
Na + OH + H + Cl --> NaCl + H2O
You might try a couple of gallons of vinegar that might be safer.
If you can get a little through it, put the vinegar in the tub and hope it drains down overnight.
To snake a tub you need to go through the overflow device. Unscrew the cap and work through that hole. If you are lucky, you might be able to pull the stuff out if it is in the tub trap. Even a thin-wire coat hanger wire with a little hook on the end might drag something out of the trap.
04-21-2006, 06:40 PM
A $25 hand snake will pull out a lot of hair, if that's what is blocking it.
http://www.terrylove.com/images/power_spin.jpg
