View Full Version : Toto question
peterh
04-18-2006, 12:43 PM
Thanks to all the good recommendations here, I'm going with a Toto. I've found a good price, however it comes with this warning --
"Water supply rough-in is wider than standard 5 1/2" rough-in. Consult your builder or contractor".
What does that mean?
Thanks.
jadnashua
04-18-2006, 01:57 PM
From the centerline of the toilet (L-R), the skirted versions of the Toto line get fairly close to the wall, and the skirt is moderately wide. "Standard" position of the supply valve coming out of the wall (or floor) will interfere with the toilet, and not allow it to be set down properly. So, depending on your situation, you might need to move the shut-off valve, or put a 90-degree on it to get it to where the toilet will work and you'll still be able to turn the water on or off. Depending on the actual flange installation (normal is 12" to the anchor bolts from the finished wall), you may or may not have enough room to use the toilet without mods to the supply line.
peterh
04-18-2006, 02:09 PM
So that means that the water suppply might not be laterally far enough away to fit the toilet in? Do you know how far from the center line of the toilet the valve needs to be away to fit a Toto? Thanks!
jadnashua
04-18-2006, 03:18 PM
Toto posts drawings of the toilets on their website...they recommend 8" from the centerline, but less should work.
04-18-2006, 11:15 PM
If you have the skirted models with the unifit adapter, then 7" center to center will work.
Sometimes if they are closer, the shutoff can be moved with a 90 el.
