View Full Version : Is this a gas shutoff valve?
lithnights
04-18-2006, 07:42 AM
I am replacing my gas hot water heater. There does not seem to be a gas shut off valve between the gas line coming into the house and the actual water heater itself.
I am attaching a picture of what appears to be some sort of shut off valve. Is it?
If not, how would one replace the heater? What are my options here? I don't want to mess with the gas company since the heater actually burst this morning and I need to get it replaced today.
Thanks,
jimbo
04-18-2006, 08:02 AM
The picture you posted appears to be a gas valve, but without seeing the rest of the setup, or the piping layout, I cannot advise you to turn this off. I would recommend you get a plumber or the gas co. out to help you with this. The gas co. will probably come out for free. Once you learn what it is and how your system is connected, then you will feel comfortable in the future if you need to work on it.
lithnights
04-18-2006, 09:09 AM
I lit the pilot light, turned what appeared to be the gas shut off, and indeed the pilot light went out. This confirms our thought that is indeed a gas shut off.
I just had never seen one like this.. it's probably original with the 40 year old house.
04-18-2006, 05:07 PM
IT is a plug cock gas valve. They are not longer permitted and should be replaced with an approved one.
dubldare
04-18-2006, 08:54 PM
A lever handled, AGA and/or CSA approved gas valve is required.
End-user/appliance shut-off valves which rely on tools for their actuation are forbidden.
04-19-2006, 07:06 AM
I have NEVER been asked to see my license, other than by a couple of inspectors, in the past 55+ years. In fact in twenty years in Chicago, I was never asked for my union card either.
shacko
04-19-2006, 01:10 PM
Yes, that is a gas valve.
lithnights
04-19-2006, 02:28 PM
OK I can see why. But I am used to working with copper but not black steel. Thus, how do you make a break in the steel line to put in a new valve?
I know threaded pieces are used along with screw on unions and screw on elbows, and thus I'm not sure how it would be done if you cut into the pipe and are left with a bare end (no threads).
I don't plan on doing this right away, but I'd like to know for the future.
Thanks,
plumber1
04-19-2006, 03:04 PM
There should be a union on the fixture side of the gas valve.
So you just undo the piping from the union back to the valve.....
Gary Swart
04-19-2006, 07:19 PM
And, if there is not union, cut the pipe and install one.
Dunbar Plumbing
04-19-2006, 09:57 PM
Those gas valves have a tendency to leak when disturbed. There is a packing gland inside of them that the old time plumbers would repack. The advice on the replacement of the valve is definitely in order.
Any gas valve that cannot be shut off by the average person is not legal. Those blade type gas valves with a hole in the center of them to allow a screwdriver to turn the blade or a crescent wrench will not qualify as a proper valve.
The 1/4 turn handle valves are the way to go. Any valve that states WOG on the side of it can qualify as well in the 1/4 turn valves.
