View Full Version : ball valve question..
harveymasons
04-14-2006, 08:48 AM
This question may or may not belong here but if someone can answer it, it would be most helpful.
I am hooking up a 1/4 x 100 ft high pressure hose to my pressure washer to do some sewer jetting, unfortunately I will have no way to control the flow of water only by turning th eengine on and off, I will not be using the wand/gun that pressure washer comes with. I Was told I can install a ball valve to start and stop water flow instead of having to start and stop the engine. I am just unsure where this needs to be hooked up, at the pump before the hose or after somewhere??
any help is greatly appreciated, and sorry for not being a 100% plumbing question.
regards,
harvey
Bob NH
04-14-2006, 09:23 AM
You need to look at the way your pressure washer operates with the wand. Is the wand just a valve, or does it feed back some kind of signal to the pressure washer. If it is just a valve, then the pump probably bypasses through some kind of relief valve.
The other thing is that you need a valve and fittings that are designed for the operating pressure of the pressure washer. Most fittings and valves that you buy at Big Orange or such places are not designed for such pressures. A mistake that rusults in bursting a line or valve could have fatal consequences.
The only place you are likely to get the proper fittings is a place that sells parts for pressure washers, or a high pressure hydraulics shop.
04-14-2006, 11:56 AM
It has to be after the pump, but it also has to be before the hose or you could not operate it. So if the hose connects directly to the pump then that is where to put the valve.
Mike Swearingen
04-14-2006, 12:14 PM
You also need to check the operating manual instructions for the pressure washer.
Mine says not to let the pressure washer run without releasing the pressure at least every two minutes, or it will damage the pump.
Mike
plumber1
04-14-2006, 12:20 PM
A check valve or a relief valve?
