Water to both Wall and Ceiling heads
smileyroget
Ann Arbor MI
I've been looking at local stores without luck for a custom shower head that would have two heads, one permanent one coming from the ceiling and one handheld coming from the wall...I can't find a valve that I can put on the wall (handheld head) that let's water flow to both, or either heads.
This website has items much closer to what I want but I haven't quite found it. I'm building the shower from scratch and can run plumbing anyway I need to. Just need the right valve and to be able to put it on the wall. the ones I've found can work but they would have to be put on the permanent shower head which would be on the ceiling, that's too awkward. Thank you, Roger
diverter
There are several ways to accomplish it. The most common is to install a two way diverter valve in the wall next to the shower valve with one outlet to the hand held and the other to the regular head.
That is four positions, so you'll probably need two valves
Roger,
Both or either one, right?
A on
B on
A and B on (both, together)
A and B off (both, together)
If you find a valve that allows all that, let me know. I'll keep reading this thread.
David
You'd need the normal volume control (and maybe a temperature, depending on the style), then a separate divertor valve. You might find a divertor with an off position, but that is not their normal purpose. Now, the thing I'm not sure of is if in the "in-between" position, it will output to both at the same time. Many manufacturers make matching divertor valve trims.
Another message asked pretty much the same question the other day
Moen 3320
Rough-in Moentrol pressure balancing volume control with built-in three function transfer valve with stops 1/2" IPS Connections
M·PACT common valve system
2 discrete functions, 1 shared function
adjustable temperature limit stop
Not recommended for tub spout application
Other manufacturers have similar valves. Many different trims are available.
pardon the intrusion
This begins to look and sound very much like my question regarding spa jets in another thread.
If I am reading this correctly I can get a diverter that could be mounted inline between the main faucets and the shower head -
Then same as described here - but instead of going to a second shower head - go to spa jets.
Correct?
What should I ask for - and who might have such animals
Thanks - and agian forgive the intrusion - just looked like our needs were very similar
diverter
Almost all companies make the diverter, and, ideally, you would get the one from the company that made your faucet so the handles and trim would match.
