Looking for a new 46" shower insert
georgepavliscak
Anyone have a supplier for a 46" wide shower. This is the actual unit size, I dont know the Rough opening size, as I do not want to remove this shower until I have a replacement in hand. I assume its probbably 47" with 1/2" dryway behind it. All the ones I have found are 47&3/4"-48" and I do not want to reframe any walls if I can help it.
Thanks alot
george
If you are talking about a one piece fibreglas shower unit, it is almost surely 48". These units fit right to the stud walls. There is no drywall "behind" them. Measuring about 46" from inside wall to inside wall would be about the right measurement for a 48" unit.
48 is pretty much one of the standard sizes . Others are 36, 54, and 60. I do not remember ever seeing a "46" so I really think you have a 48.
Now, are you sure you can get a new one piece 48" into the room and into position? I doubt it. These are literally installed before the walls go up. What you will need is referred to as a "remodel" unit, and it will be two or three pieces.
As far as a door, I don't know what you have now, but most codes not longer allow a bypass sliding door on 48" width. Too narrow opening. You will need a pivot door with fixed panel. These are readily available to fit your 46" opening.
Shower Wackiness
Owens Corning apparently made a 46" wide for some time and that is what this unit is. I know many are tiling the opening rather than reframe. I do not mind reframing, but I would really like to keep what I have go here.
There is 2" difference between current standard 48" shower and this unit.
