repalcing old galv. pipe?
rvt2096
I have a small leak in an old 1/2 galv. pipe under my house. The run is 10 feet long and of course the leak is in the middle. The pipe is screwed on a 3 way galv. fitting on both ends....the space is pretty tight (crawl space)..my question is how do I replace this with a new copper pipe and also connect it to the 3 ways....?
Thanks,
Rick
Well, this is not from experience, but from a technical viewpoint (there may be an easier way). Hacksaw out a section in the middle, then unscrew each end (you probably will need two wrenches to hold the fitting from moving around too much while you take out the old pipe). If what's left has a little movement to it, use a dielectric union on each end with a new copper piece inbetween. If those ends don't have any play so you can insert the pipe into the fittings, then it gets messier. Then you'd need a repair coupling to connect the two pieces of copper. A repair coupling doesn't have a stop in the middle, so you can slide it entirely over the pipe, meaning that you won't need to spread things apart to insert it into the pipe; just slide it over one end, get the other side lined up (after cleaning both the fitting and the ends), and slide the fitting so it is centered on the joint and solder it up.
Now, note that when unscrewing the old pipe, you might just create other leaks and this may be a good time to replace those pipes/fittings as well. It is only a matter of time...
Aside from re-piping I would just cut that piece out and get a new piece the same length including a nipple and a union. For only 10 ft.. Keep it iron pipe.
A repair to the old line will buy you some time, but it sounds like you're due for a copper repiping job soon.
