Drain elbow needs to turn, suggestions?
mgrada
I've just installed a new sink an base cabinet combo, but the pvc drain pipe coming through the floor attached with pvc cement to the 90 degree elbow needs to turn (1/4 turn) so that the sink/cabinet combo will meet the wall. Any suggestions? I really dont want to cut the pvc and peice it all back together.
If your drain line is coming up through the floor, it sounds like you must have an S trap, which is not allowed by code.
As far as the pipe issue, there is not way to turn a glued fitting, You will have to cut it and put it back with a coupling.
