Leaking pressure test
Mad Plumber
Mad Skills
I've been pressure testing my new supply lines all morning. Seems the air escapes slowly over a period of 5 or 6 hours. I've been applying soapy water to all he joints but haven't found any leaks.
The air must be getting out so how
bill from jersey
When I test gas lines for leaks, I use straight dishwashing detergent. I think the heavier viscosity helps, but it's just my opinion. Other than that, turn the water on. Problem with that is, if/when you find any leaks, the lines must be drained dry to repair them and bad joints will have to be redone. The good side of that is a slow water leak will be much easier to see than air.
Did you check the schrader valve that you used to fill the system?
