rdtompki
03-11-2006, 08:03 PM
I need to install a Hansgrohe whirlpool rough-in (valves, faucet, handshower) in a pretty tight whirlpool tub enclosure (tighter than I expected!). The rough-in comes with short 1/4" type "K" copper tubing (3/8" OD) which puts the individual components on 5" centers using compression fittings. I've only got one location for which this will work and accessibility after I drop in the tub will be nil. I'd like to separate the valves from the faucet (with diverter) and handshower, but I don't know how best to do the connection over what will be a 4-5' run. Certainly, I don't want to run 3/8" OD flexible copper as I'd be concerned about diminished flow - I need to get 60 gallons into this tub. I can run 1/2" copper pipe, but what then is the best way to terminate the copper pipe and then connect to the rough-in?
After looking over the options it seems like a 3/8" to 1/2" compression coupling should do the trick, but is there anyway to avoid the stub of 3/8" OD pipe between the valve and the compression union? If I have to go this route I'll make sure to support the 1/2" OD soft copper very near valve.
I can plumb around this tomorrow, but I've got to get this figured out soon!
Rick
Rick
