View Full Version : All Elbows
Amatuer123
03-10-2006, 10:25 PM
Hello, I am installing a shower fixture and I’m trying to ensure I do it properly. Below is a picture. I need to bring the fixture out a bit to accommodate a change in the shower base dimensions. There are galvanized supply pipes coming from the ceiling. I’m attaching a dielectric union and then two or three 90 degree street elbows, a small copper piece and then a male adapter which attaches to the fixture. I’m applying wood glue… :eek: solder of course. My concerns are too many twist and turns. I guess I can just take the second street elbow out and make it a horizontal piece. I’m also unsure if soldering street elbows is adequate as they seem to have a looser connection as compared to say a street elbow connected to a regular piece of copper pipe. Any advice is greatly appreciated.
RioHyde
03-11-2006, 05:32 AM
That will work out fine. The way I'd do it however would be to cut a piece of copper the correct length for the drop, turn a 90 onto a street 45 (or 45 if need be) then cut a piece of copper for the horizontal between the 45 and the male adapter. This will eliminate one 90 and replace another with a 45.
The one thing I would be concerned about would be access to the dielectric unions. If these are going to be in a wall you'll need some way of getting to them to service in the future.
There is no problem with soldering street fittings. It is done thousands of times a day without incident.
Amatuer123
03-11-2006, 12:01 PM
RioHyde, thanks a bunch! I'm learning you can be a little creative w/ this stuff which is great. I'll probably make an access panel on the wall behind the fixture. Why would the dielectric union need to be serviced? Threading weakness, etc.?
03-11-2006, 01:03 PM
PRobably never, but it does have a rubber gasket that could deteriorate, and even though it is a "dielectric" union, it could still fail, or rust, because of electrolysis. They are more decorative than functional.
RioHyde
03-11-2006, 09:22 PM
HJ,
EXACTLY! I have a few members on my crew who swear by dielectic unions. However I've had to replace far too many of them due to corrosion/rust to have any faith at all that they'll last forever.
