View Full Version : Cleaning Tile Kitchen Counters
BJW
03-05-2006, 03:29 PM
After having read all the tips and advise on sealing tile and grout, I'm pretty clear how to clean, maintain, and protect my new bathrooms. Each bathroom is now, or will be, tiled.
Unlike the bathrooms, the new kitchen tile, which is drying as I write, will be used endlessly. Sometimes my counters are whipped down a dozen or more times a day. In the past, I've simply cleaned my counters with soap and water, using the same product as I use for hand cleaning the dishes, and then following up with an antibacterial whip. What now would be the best approach or products to use for this type of continuous cleaning up without hurting the new porclean tiles and Hydromount dry tile grout?
By the way, this site has been a wonderful find for me. I've been reading and reading and learning so much. What a helpful experience.
Thank you for sharing.
BJW
p.s. What's "post a poll" mean?
Lakee911
03-07-2006, 06:40 AM
Check out the forum over at John Bridge (http://www.johnbridge.com/vbulletin/index.php) for tile info!
A poll is like a suvey. You could say, "Which product do I wipe my counters with?"
Options for Product A, Product B, Product C and let them vote and see the rankings.
jimbo
03-07-2006, 07:43 AM
The secret for kitchen counter tops is to seal the grout. Get a top quality sealer from someone like TileLab, and redo the sealer twice a year.
Lakee911
03-14-2006, 07:49 PM
Don't they have some rubbery silicone type faux grouts for kitchen tiles? Oh oh...I read some where...The Family Handyman, April 200, Page 106. No-stain grout. Apparently made with 100% recyucles glass spheres. No staining since the aggregate isn't jagged like sand. Prism SureColor grout from Custom Building Products
800-272-8786
www.custombuildingproducts.com
Jason
jadnashua
03-14-2006, 08:04 PM
If you want to go for the extra expense, you can use an epoxy grout. Then, no sealers are used (unless the tile is porous like some stones). These are often specified in commercial kitchens and can take the abuse. They don't typically stain, either.
If you use a cement based product, you would want to use a ph neutral tile cleaning product. Repeated use of acidic products will play hell with the sealer and actually (eventually) start to eat away the cement in the grout. As noted, a really good resource on tiling questions is www.johnbridge.com
