View Full Version : Two piece toilet leak
Yelsikmij
03-05-2006, 01:29 PM
I installed a Toto Drake two piece toilet and have had a slow leak for a few weeks now (off and on) from one of the bolts which attach the tank to bowl. I tightened to the point I thought was as tight as I could without cracking the tank. I also tried disassembling and reassembling the two parts. Same result. Could the leak be from the main connection from tank to bowl and then leaking out the bolt (the rubber gasket not working?) or is it simply the bolt should be tighter. How do you know when it is tight enough? Any advice??????? I never installed a toilet before and seemed to be easy enough..just that darn slow drip.
jadnashua
03-05-2006, 01:32 PM
http://www.terrylove.com/wc/toto/drake_sand_bolt3.jpg
turn off the water, flush the tank, sponge out the remaining water. Take the bolt out, then take some fine sandpaper and smooth the area around the bolt hole on the inside of the tank. Reassemble - make sure you put the washer in the proper place.
http://terrylove.com/forums/showthread.php?t=743&highlight=cst744s
toolaholic
03-05-2006, 02:02 PM
same problem with my 2 totos,when i rebuilt them . I used rector sealunder the washers,NO LEAK! work's for me :D not all agree
plumber1
03-05-2006, 07:46 PM
You can also use a little plumbers putty under the bolt head and washer........
