Pex Piping Systems
tazman139
Does anyone have and thoughts pros and cons and either the Vanguard or Wirsbo pex system. Want to repipe my house but can't decide on which method to go with. Have had several pinhole leaks in my copper pipes and need to change before fiinishing lower level of home. Thanks for any comments.
I just reciently started using PEX and in the right situation, like yours, it would work very well. Since you will be closing the ceiling I would build / buy a manifold and run seperate lines to each fixture with a shutoff for each line.
Pex Piping System
Thanks for your comments. Have been thinking about using the manifold approach.
The crimping tools are expensive but you can buy a small, slow to use version on the big auction site for $39.00.
