View Full Version : bypass shower doors
JEP
03-03-2006, 09:03 AM
I'm not sure this is the right place in the forum for this but here goes. I'm installing bypass shower doors on a standard 5' tub. The upper and lower tracks need to be cut. Any tricks, or ideas on how to get real nice straight cuts on these? Is there something better to use that a hacksaw that will give me a more square cut? Would some kind of blade in a chop saw do it?
sulconst2
03-03-2006, 09:08 AM
i use a regular blade in a chop saw. just cut real slow and wear glasses. then a file on the rough edge. perfect cut!
Gary Swart
03-03-2006, 09:30 AM
A small miter box and hacksaw will work OK, but work slowly. Use a file to remove any rough or sharp edges.
JEP
03-03-2006, 09:34 AM
Thanks for the responses guys. I'm going to give the chop saw a shot. I'll do a test cut on the very end to see how it goes.
Sulconst2 - Do you face the top (solid) side up or the track side up when you cut - or doesn't it make a difference?
sulconst2
03-03-2006, 03:33 PM
solid side up would probably be better just go slow. don't forget the glasses! :eek:
jadnashua
03-03-2006, 03:40 PM
I've cut two of those with a 60-tooth blade on a radial arm saw. The carbide can handle the aluminum fine, but go slow so you don't bog down or overheat anything.
sulconst2
03-03-2006, 07:06 PM
definitely the way to go. its finish work. really sticks out if its a bad cut. been using a chop saw for years on these. just turn your head cause it spits metal all over. but the cut is sweet!
JEP
03-04-2006, 10:01 AM
Cut like butter. Thanks guys.
